- TomC71Explorer
enblethen wrote:
Have you checked your private messages?
I did now lol. I replied to it.
I have to check to see if there is a setting that actually lets the forum notify me on private messages because I didn't even notice it at the top of the page until you said this. - TomC71Explorer
Y-Guy wrote:
Heads up to all, including the OP, drop the insults and crude language. I'm not in the mood to play hall monitor today.
Read the thread and examine my responses to those who were helpful compared to those who decided to take issue with me.
Then, note that I blocked those who were here simply to troll, which your forum continued to allow them access to my post and the ability to reply.
I came here for info and was polite and thankful to those who offered useful info and attempted to block those who weren't. - 2112Explorer IIThe cheapest way is to plug your shore power cord into the inverter using a $6 Adapter and turn off/disconnect the converter and microwave. The microwave draws a little current so I turn it off as well when using my 500W inverter. Have the fridge and water heater on propane if using them.
I also have a 100W inverter that plugs into the cigarette plug above the TV. That plug is only good for 8 amps. I use it for watching TV and charging our electronics. That's an isolated circuit so I don't need to worry about the converter. - Y-GuyModeratorHeads up to all, including the OP, drop the insults and crude language. I'm not in the mood to play hall monitor today.
- Have you checked your private messages?
- TomC71ExplorerActually I'll respond to the last poster even though I blocked them as well.
Yes, we were homeless until we bought this trailer and found someone kind enough to let us rent some land from them cheap. Our alternative was to live in a tent.
I don't know what is wrong with the people here on this forum, but I wouldn't even let most of you near my property let alone take advice from most of you. I ask questions to get other people's input. Whether I choose to follow them blindly, or whether I choose to do what is actually possible in our situation is up to me. That it offends some of you that people don't do what you say, says much more about you than it does me. - StirCrazyModerator
Grit dog wrote:
StirCrazy wrote:
if you decide to sell the rv later the new owner will thank you instead of powsting on here "I cant get my AC to work" panels are easy to change and not that expensive. at 37 years old you should replace it anyways if you are charging batteries with it, or just want filtered dc power for your electronics.
Pretty sure the market for 40 year old rolling meth labs is pretty small... I wouldn't worry about the "next" consumer to get ahold of this beauty of a trailer..lol!
:B - 3_tonsExplorer IIITomC71, I notice that you’re a new member…Rather than displaying vulgar bitterness (recall, you never mentioned ‘money’, eh??) you might ‘appreciate’ that most of us here are interested conveying a safer, rational method and have invested personal time attempting to assist you…As per the principle of personal ‘free agency’ quite naturally you free to do what you wish - Good luck
3 tons - 3_tonsExplorer IIIFrom just my perspective, seems more like what the OP is seeking is a tutorial and concurrence for an unsafe wiring scheme…
3 tons - StirCrazyModerator
TomC71 wrote:
ewarnerusa wrote:
because it is simpler? The only additional thing powered would be the air conditioner. which as you said, you never run.
Simpler in the short term maybe. Not if something in the 37 year old converter/panel box goes on the fritz. This way I don't have to worry about it.
if you don't want to screw with it add a auto transfer switch and power the whole power center. if you don't want to use the AC then turn off the braker for that and just use the plugs. I havent said anything up to now but I cant stand half assed jobs. your going in there anyways just put in a auto trans fer switch, feed one side from the shore power feed the other from your inverter and done. if you decide to sell the rv later the new owner will thank you instead of powsting on here "I cant get my AC to work" panels are easy to change and not that expensive. at 37 years old you should replace it anyways if you are charging batteries with it, or just want filtered dc power for your electronics.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
