schwartzworld's avatar
Jul 21, 2015
Travel'r awning issue
We have a Carefree of Colorado Travel'r awning. It went out but didn't come back in. No noise, nothing. I got a ladder and I was able to turn the tube while my wife hit the button. It then very slowly went in. I called Carefree and they gave me some trouble shooting to do. I hooked the motor right to a cordless drill battery and it went in and out very quickly. The battery was an 18 volt which Carefree said was OK. Being higher than 12 volts it should move quickly. I checked the voltage at the wires to the motor. With the switch in either direction we had 12.45 volts. At the switch I had the same voltage. Battery water was checked, it's at the correct level.
Any ideas why it stuck out? I can run it out half way and it will come back in. Haven't tried all the way yet. Could the motor still be bad? If they would send me one under warranty I think I have enough people to help me change it out.
Thanks
Fred
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
