mfeveleth's avatar
mfeveleth
trav'ler duette stove parts
I have a tiltin hiltin which is need of some stove parts for a trav'ler duette 183-60. Any help would be appreciated.
Well I haven't heard anything yet. Wondering if any one out there knows anything about the older propane stoves. Mine seems to have a mercury thermo coupler switch. Not sure how it works or why it wouldn't work.
I can get the pilot lit but when I release to button it won't always stay on. I have removed the stove from the camper and dismantled the stove to where I can now easily see the pilot assembly. I have cleaned it with carb cleaner & brake clean and did find the thermo not completely in it's bracket, so maybe that was a fix.
I also have a aluminum tube the comes from the pressure regulator that is where the propane hooks up to the stove. If it attaches some where I haven't a clue where so am wondering if it just is the by the pilot and what it is there for.
My fan for the heater part still works so rather than counting on the thermostat "switch" to work and turn the fan on and off when the oven reaches the set oven/heater temperature I may just put an on/off switch and just have the fan on when I want to use the heater.
Was also wondering if there is a way to test the stove on/off switch, breaker, and thermostat switch with some kind of tester.
I love this ol'e camper and just want to have it work a closely to it's original design as possible, so thanks again if anyone can help me or lead me to someone who might be able to help.
1 Reply
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
