wa8yxm
Apr 26, 2021Explorer III
If it is determined that is out of warranty.. you can replace the outlet
I was able to do it using the existing pigtail however that is not all that easy to do.. you can get a new pigtail. open the box (Carefully.. Replace the outlet end and re-close the box.... Of course if you do not feel comfortable doing this. DO NOT DO IT.
Yes that is a common failure of 50 (And even worse for 30) amp outlets and plugs NOT specific to any make or model (the replacement I used was bakelite type (hard plastic) and did not have that problem. though I did have to dissassemble it and clean the contacts a time or two)
Option 2 is to go hard wired.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
