- MEXICOWANDERERExplorerA mini grinder and rasp can dig out epoxy fill. 50-amp wiring could be 6-gauge. Soldering plus several applications of 3:1 heat shrink tubing with sealant could make a strong pigtail socket.
- CA_TravelerExplorer III
TenOC wrote:
OK Your plug is molded vs the unit.CA Traveler wrote:
Is repair cost to high? Are you thinking of adding a 50A pigtail?
I do not understand your comment. Non Repairable. All one molded part.
Have you contacted the mfg for repair cost?
As a DYI person I'd take the unit apart to see about replacing the pigtail. If not then add a short pigtail with the individual wires and the entire splice encased in adhesive heat shrink. - TenOCNomad
I do not understand your comment. Non Repairable. All one molded part. - CA_TravelerExplorer IIIIs repair cost to high? Are you thinking of adding a 50A pigtail?
Use caution - if you wind up with a compromised neutral you WILL have excessively high voltage in the RV. - TenOCNomad
fj12ryder wrote:
I've had two fail, and the last one had about 1/2" of water inside when I pulled it apart due to the plug doing exactly what you describe.
How did you get it apart????? All is molded together. - fj12ryderExplorer IIIIME with the Surge Guard units, I would check the unit for water intrusion. I've had two fail, and the last one had about 1/2" of water inside when I pulled it apart due to the plug doing exactly what you describe. I changed brands after that happened.
- TenOCNomadHas anyone tried to cut off the old outlet and wire in a replacement outlet? I think I can use a multitool to cut the old plastic off the wire and still have room to rewire a replacement socket.
LouLawrence wrote:
I'd be suprised if any common plug is physically the same, the connector locations are standard of course.
Can you just replace the plug?
This is one reason I installed the PI hard wired unit with field replaceable parts. - TenOCNomadThe FEMALE flat center socket is the only damage. The male that plugs into this female look OK.
- LouLawrenceExplorer IICan you just replace the plug?
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 19, 2026
