chilly81's avatar
chilly81
Tricks to stop leaking pipe thread
I put in a new anode this year on my HW heater and I used pipe dope. This is the first I'v used it, but I gobbed it on good. I typically used teflon tape, but I knew the threads were a bit rusted and thought dope would be better.
So it's weeping now. I did clean the threads as best I could with a wire brush on a dremel.
I wouldn't feel comfortable torquing it any further - although I can't say the actual torque. Are there any tips or tricks to make it stop... or does a very light weeping often stop on it's own after a couple days?
Does teflon tape actually work better and I was just dumb?
Any tips or advice welcomed!
Thanks
  • Try just letting it sit a couple of days without any pressure.May just may rust and swell.Have seen it work.Not something to count on.Cost is cheap.
  • I'd get a 3/4 inch pipe tap and clean up the threads (gently). Unless you have some serious wire brushes on your dremmel, I doubt you hurt anything.
    I use teflon tape, but that's just an ease of use and longevity of tape verses dope.
    Doug
  • Go to some place like Harbor Freight and buy a 3/4 pipe tap. Use that to clean the threads. It is quite possible though that you have already damaged the threads using your Dremmel.
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 10, 2025
