chilly81's avatar
chilly81
Tricks to stop leaking pipe thread
I put in a new anode this year on my HW heater and I used pipe dope. This is the first I'v used it, but I gobbed it on good. I typically used teflon tape, but I knew the threads were a bit rusted and thought dope would be better.
So it's weeping now. I did clean the threads as best I could with a wire brush on a dremel.
I wouldn't feel comfortable torquing it any further - although I can't say the actual torque. Are there any tips or tricks to make it stop... or does a very light weeping often stop on it's own after a couple days?
Does teflon tape actually work better and I was just dumb?
Any tips or advice welcomed!
Thanks
  • Try just letting it sit a couple of days without any pressure.May just may rust and swell.Have seen it work.Not something to count on.Cost is cheap.
  • I'd get a 3/4 inch pipe tap and clean up the threads (gently). Unless you have some serious wire brushes on your dremmel, I doubt you hurt anything.
    I use teflon tape, but that's just an ease of use and longevity of tape verses dope.
    Doug
  • Go to some place like Harbor Freight and buy a 3/4 pipe tap. Use that to clean the threads. It is quite possible though that you have already damaged the threads using your Dremmel.
