dougrainer
Nov 29, 2015Nomad
Don't know about Winne, but MOST motorhomes have a spring loaded pins(2) on the hinge side of the entry door. One pin will be 12 volt positive and the other negative when the FOB or wall switch is activated. Better to check for 12 volt THERE first before you take the door apart. If you have 12 volts at those pins then yes, the signal either not getting to the motor or the motor is bad. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
