dougrainer
Nov 29, 2015Nomad
Thunder Mountain wrote:
Well I found the problem. The wires in the door frame were not crimped to the spring connector and had come loose. Got to call Winnebago and find out which wires go where. It should be a no brainer since the wires are all numbered.
If it is just the 2 wires, you have a 50/50 chance to get it right. NO HARM if wrong. It will just operate in reverse if the wires are crossed---Lock when calling for unlock and unlock when calling for lock. The Lock motor operates on reverse polarity. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
