hedge
Apr 13, 2017Explorer
Just a heads up... probably obvious but thought I'd point out that if you want to use the meter to measure the current from your portable panels you'll have to connect the portable panel to the correct side of the shunt, if you connect directly to the battery the meter won't 'see' it.
