CA_Traveler
Apr 13, 2017Explorer III
RobWNY wrote:Unfortunately the unit is unaware of battery self discharge so other than short periods w/o power it needs to relearn SOC anyway.
I got this response from Bogart Engineering. "The TM-2030 will retain most of the settings when powered off; however, it will not retain the State of Charge. When powered back on, the monitor will relearn the state of charge if the system goes through a complete charge cycle; or you may manually reset the TM-2030 when the batteries are 100"
