Almot
Apr 23, 2014Explorer III
Doesn't need to be next to your OEM "monitors". You can remove a sheet or two of the under-belly if you have to, but (probably) will be a pain when I look at all those sheet metal screws in the frame. When you remove it, there will be (should be) holes in the metal cross-members here and there.
Victron looks nicer, less obtrusive. Cheaper too.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
