DieselBurps's avatar
DieselBurps
Trimetric questions
Hello, I am just a beginner truck camper and I have a few questions about using and programming my Trimetric battery monitor. I hooked it up last week along with a new battery converter 3 stage(Boondocker converter) I bought from bestconverter.com. I had a 12 volt worn out interstate battery originally and when it was low at 10 volts according to the Trimetric and I plugged in the amps would start out at 40 and as the battery charged being plugged in it would gradually decrease until amps read 4 and the battery volts 13.6. I soon realized that as I was driving down the road my truck was not charging the battery and it was soon at 10 volts after 300 miles of driving, well I solved that problem and added a fused wire back to the 7 pin so now it charges as I am driving or maintains charge. Since I got that out of the way I decided to purchase a new battery, I went with two 6 volt batteries from Costco since I had 70 dollar gift card, got those installed today and volts now say 13.5 and 7 amps. I am assuming the battery is now being trickled charged? How high should my volts read to tell me the batteries are fully charged? I thought it was supposed to be 14.6 or so? I believe that is the default setting in trimetric, and the battery must hit that in order for the % full to display (right now % full is blank with two dashes). Is there something wrong with my converter? Shouldn't it bring my batteries all the way to 14.6?
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
