DieselBurps's avatar
DieselBurps
Trimetric questions
Hello, I am just a beginner truck camper and I have a few questions about using and programming my Trimetric battery monitor. I hooked it up last week along with a new battery converter 3 stage(Boondocker converter) I bought from bestconverter.com. I had a 12 volt worn out interstate battery originally and when it was low at 10 volts according to the Trimetric and I plugged in the amps would start out at 40 and as the battery charged being plugged in it would gradually decrease until amps read 4 and the battery volts 13.6. I soon realized that as I was driving down the road my truck was not charging the battery and it was soon at 10 volts after 300 miles of driving, well I solved that problem and added a fused wire back to the 7 pin so now it charges as I am driving or maintains charge. Since I got that out of the way I decided to purchase a new battery, I went with two 6 volt batteries from Costco since I had 70 dollar gift card, got those installed today and volts now say 13.5 and 7 amps. I am assuming the battery is now being trickled charged? How high should my volts read to tell me the batteries are fully charged? I thought it was supposed to be 14.6 or so? I believe that is the default setting in trimetric, and the battery must hit that in order for the % full to display (right now % full is blank with two dashes). Is there something wrong with my converter? Shouldn't it bring my batteries all the way to 14.6?
