Empty_Nest__Soo
Mar 19, 2015Explorer
Grizzzman – My concern was at what point does the cross-sectional area of the conductor (the bracket) become small enough that it gets hot from resistance and perhaps burns in two? Same principle as a fuse.
But, I suppose if the voltage drop across it is so negligible, then the heat generated from the current passing through will also be negligible?
Wayne
Wayne
