Empty_Nest__Soo
Mar 20, 2015Explorer
Grizzman – Thanks for that. It all makes sense now.
Yes, I’m using the 500 amp shunt. Given the 2000 watt inverter in my coach, I figure it is appropriate to allow for 200 amps from the batteries.
But I figure 200 amps is allowing a big cushion for safety. In practical terms, the biggest load passing through is likely to be 100 amps when charging from the inverter/charger. I don’t expect to use the microwave or other big appliance from the inverter when boondocking, so probably a toaster will be the biggest single draw.
When not boondocking, I would expect to be running directly on AC line voltage, so the batteries would be mostly out of the loop.
Wayne
Wayne
