EMD360's avatar
EMD360
Tripping solar panel breaker
Last fall I installed two Solarland 180w PERC panels. I had ordered three 100 watt but changed my mind and bought the two 180’s. Unfortunately I didn’t resize my order for the panel breaker which is 15 amps. The 100 watt panels were rated for five amps each but these are at 9.42 each. So now that we are getting really sunny days my panel breaker is tripping. I thought ok I’ll have to replace it with a 20. But I was watching the power when I was trouble shooting and thought I might have briefly seen more than 20 amps. Would a 30 amp fuse of these two panels be too high? The MPPT controlller is Victron. The system side breaker is 40 amps.
  • EMD360 wrote:
    2oldman wrote:
    I don't know why you have to fuse panels.
    Apparently you don’t if wired in series. The amps are not high enough to damage the wires if there is a short circuit.
    That’s what the windynation site that was shared explained.
    I still did for mine, I did both the panel side and the battery side of the controler with manual tripable breakers so I can use them as a disconect if I have to do any work.
    Steve
    Steve
    X2
  • Just reporting that the upgrade to a 30 amp breaker on the panel side worked. But of course the amps I was reading were below 15 when tested.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
