EMD360's avatar
EMD360
Tripping solar panel breaker
Last fall I installed two Solarland 180w PERC panels. I had ordered three 100 watt but changed my mind and bought the two 180’s. Unfortunately I didn’t resize my order for the panel breaker which is 15 amps. The 100 watt panels were rated for five amps each but these are at 9.42 each. So now that we are getting really sunny days my panel breaker is tripping. I thought ok I’ll have to replace it with a 20. But I was watching the power when I was trouble shooting and thought I might have briefly seen more than 20 amps. Would a 30 amp fuse of these two panels be too high? The MPPT controlller is Victron. The system side breaker is 40 amps.
  • You need to check the rating for the controller. I have a Blue Sky rated for 30 amps, hence I have a 30 amp fuse.
  • See this article from WindyNation regarding solar panel fusing…
    https://www.windynation.com/jzv/inf/how-properly-fuse-solar-pv-system
Having RV issues? Connect with others who have been in your shoes.24,316 PostsLatest Activity: Sep 12, 2025
