You get 300AH with a pair of T-1275s. They gas nicely when recharging similar to the way 6s do, and unlike the hard to recharge marine/rv 12s. The T-1275s are great with inverter high amp draws for less voltage drop than Wet 6s. A pair of 105s is 225AH, so 300 will be less resistance just from that.
I had a post here about my old T-1275s if I can find it. No luck.
I got two used ones from a golf car place that were two years old at 85% according to their way of measuring things. I equalized them and nursed them back to 90% by load test at the 20hr rate for 10 hrs to 50% and used them fairly hard in the RV for five years. They finally got too low in capacity last winter, so they did really well. They held in the high 80s to near the end, then sort of died down fairly quickly.
Two new ones looked after from the start would be awesome. I now have an AGM 6GFM250, (8D format-148lbs) which acts something like the pair of T-1275s,( 82 x2 = 164lbs) so that would be another way to go perhaps.
