wa8yxm
Dec 12, 2020Explorer III
Back to topic. First if you have not already done so identify make and model and then go to Google or other search engine and type make model manual pdf and hit ENTER.
Download to hard drive and read it.. NOTE the manuals tend to cover mutiple models
On the control board (likely left side of unit on outside) there is a multi-pin connector Identify the SAIL SWITCH pins. one should have 12 V on it when the blower blows.. So SHOULD the other but as someone suggests might not.
How to access that blasted switch... I've never done that so sorry.
If the switch is closing then the next suspect I'm sad to say is the control board I suggest having it tested at a RV dealer (many can do it at the parts desk) and Dinosaur Boards if you need a replacement.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
