RiverRvr
Jun 18, 2014Explorer
Problem solved or the beginning of a new one!
Started by checking all 110 volt breakers and even going as far as to test continuity of each breaker, I found none tripped. Although, I had checked the breakers on the inverter unit last night. I decided to revisit them. After disconnecting shore power and reconnecting several times in my quest, I found one of the breakers tripped. Pushed it in and the smoke rolled out of the inverter. After the smoke cleared, everything works as it should. For now.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 06, 2026
