road-runner
Oct 27, 2020Explorer III
All you can do on your own is see if the problem could be caused by the wiring external to the inverter module, which will require a bit of disassembly. My first step would be to disconnect the AC output wires to eliminate the outlet, circuit breaker, damaged wires, and parallel connectors as causes. (See the wiring diagram in the owners manual). If that didn't work I'd open up and re-mate all of the connectors a couple of times on the chance that could clear up a flaky connection. If the failure is inside the inverter module there's nothing to be done other than replacing it or walking away from the generator.
