MrWizard
Dec 10, 2016Moderator
Chris Bryant wrote:
Y'all are missing the fact that the inverter is powering the microwave while the genset is running. If it were a transfer switch problem it would not be able to do that. I maintain it is a power quality issue- the inverter doesn't like it, so it keeps inverting.
Chris you could be right
But that depends on the MW being on an original oem circuit
And not a new circuit directly from the inverter (with or with out sub panel)
I've run all sorts of generators with converters, inverters, chargers, and never had a one that refused to come on charge
Now syncing with the wave form and providing load support is something else, need a very clean 120vac for that
And what if anything in the tt does work of the generator ?
The opp only complained about the MW running down the battery
Does his a/c work from the generator?
