3_tons
Dec 10, 2016Explorer III
MrWizard wrote:Chris Bryant wrote:
Y'all are missing the fact that the inverter is powering the microwave while the genset is running. If it were a transfer switch problem it would not be able to do that. I maintain it is a power quality issue- the inverter doesn't like it, so it keeps inverting.
Chris you could be right
But that depends on the MW being on an original oem circuit
And not a new circuit directly from the inverter (with or with out sub panel)
I've run all sorts of generators with converters, inverters, chargers, and never had a charge that refused to come on charge
What here is preventing an out-of-phase conflict between the different power sources??
