enblethen
Jul 08, 2018Nomad
Here is manual
RM 2610 manual
Start by verifying there is 120 volts AC available in the exterior refer access panel. Plug in a known good device.
Disconnect 120 volt plug. Locate the two wires that come from the circuit board and go to the stack on the right side. Disconnect one of the wires. Test between the two wires for continuity.
Locate the element wire at the circuit board. Plug refer back in, set unit to AC, test output of the circuit board for 120 volts AC between the two output terminals for the heater. No power, bad circuit board.
RM 2610 manual
