Chris_Bryant
Jul 09, 2018Explorer II
A couple of things, that cam switch and the shaft and knob can get sloppy, sometimes you go past the elec setting.
When testing, keep in mind the hot *and neutral* run through the switch, so you can't just ground the meter to test.
Most common failure will be the element, though.
