BigCat77
Jul 12, 2019Explorer
I was able to successfully get it running on LP and it starting to cool down.
There are 2 elements going into it and it appears there is one to the DC switch and one going to the AC switch.
The element going to the DC switch has 2 wires, where one goes directly to the switch and the other down to a ground block where there is a pigtail fuse coming off of it and it appears pos and neg from the converter.
I think i need to pull out the other wire to successfully test resistance on that element.
The element going to the AC switch has 3 wires, 2 white wires and one green wire. Im not sure how to test resistance on these so Ill keep searching the inter webs.
There doesnt appear to be any burnt or loose wires from inspecting so far.
