BigCat77
Jul 12, 2019Explorer
Yah, I tested the element disconnected. I went through all the connections and everything looked fine.
I however did find the issue. The house outlet I was using I thought was a 20 amp but it turned out to be a 15 amp GFI breaker (outdoor socket). After keeping the shore line plugged into that I then plugged the fridge into a outlet on a standard 20 amp breaker and its working fine.
I swear I had tested different outlets before but either way everything seems to working as should.
I appreciate everyones help and I have learned a lot with your assistance.
Thanks again and safe travels,
Forrest
Forrest
