You_can_t_take_
Oct 20, 2016Explorer
tmoneysju wrote:
I bought a new battery when I got the trailer because I wasn't sure of the condition of the old one
So far I've gotten a good reading using a multimeter from the battery posts (+- about 13 volts)
I've visually inspected all fuses and replaced the 3 20a ones just for good measure
Kevin
First of all.. are you sure that the terminals are connected properly. You wouldn't be the first to make that mistake.. and is it possible that you received it incorrectly wired and just reconnected it wrong? Secondly.. there will be a fuse somewhere between the positive lead and the converter. See if you can locate that and check it. That is likely the cause of your problem.
