cdcorpe's avatar
cdcorpe
Trucharge 40+
I have a truecharge 40+ about 12 years old & lately the max charge rate is 30 amps according to the remote guage.My 6 volt batteries (2) are about 5 1/2 years old & I have a battery disconnect that I can use to charge the engine battery if needed. When charging either battery or both when they were about 50% discharged the max amps is 30 amps (I know it splits the charge when 2 batteries are charged)I don't see a big difference in charging time, but it use to start at 40 amps on the same 6 v. batteries. Is it the batteries? The engine battery is new. Thanks for any help.
  • If voltage is steady (at set point, at the charger) and just the amps are sagging I believe it is a battery issue. An equalization charge may help.
    If voltage and amps are low then it is probably the charger.
  • I am home now & they are fully charged, I think it starts at over 14 volts, but I did not note that when the battery was at about 50%
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
