pianotuna wrote:
Any chance of you using two meters to monitor the voltage before and after the autoformer?
My generator is a bit larger at 2800 watts (Yamaha sIEB), and will start the roof air in eco mode--but voltage tumbles way way down (about 90 volts). I've successfully used the Magnum in load support to help with starting--but it does cause the red "fault" light to come on. I do have the microair added to the roof air.
I'll have to try using the Sola Basic autoformer between the generator and the RV.
Will be kinda busy tomorrow but I’ll see what I can do (readings may have to wait till Monday - I’ll PM you the results)....Sounds like our systems are very similar, so I’d bet you’d see a similar or same result by positioning the Sola Autoformer just after the Yamaha...
3 tons
