azrving
Oct 23, 2018Explorer
As they said, pull a hub and disassemble. If you go to a site like etrailer you can match the numbers and probably figure out who made the axle. The bearing and seal numbers should be visible. Sometimes it's handy to have an inexpensive vernier caliper when dealing with axle shafts, bores etc. When you get the parts figured out make a list to have on hand of what your axle uses.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
