huskyfan68
3 years agoExplorer
trying to winterize without pump
So I was able to get most of the pink stuff into the lines by adding antifreeze to fresh water tank and pumping through- I didn't quite finish and need to add more to winterize outside shower. Now the water pump turns on but is not pulling anything up from talk. I disconnected the inlet side and tried to get it to pump that way right to the bottle. It is not pulling anything through. it hums but nothing. Is there any other way to pull the pink stuff thru the system without a pump? is there something simple i can troubleshoot with pump? I don't know of any way to get it thru the city water inlet. Since i already have a good amount of pink stuff already in- i don't really want to blow everything out with air- Any suggestions?
