Ron3rd's avatar
Ron3rd
Explorer III
Jun 26, 2017
TST 507 sensor question
I've got the TST 507 system, about 5 years old and it works fine. I want to replace the little valve stem seals in the sensor (where it seals against the valve stem) and my question is; how do you get the old seals out??!! I'm using a small pick and it's being difficult. For those of you that have replaced these seals, any tips are appreciated.
  • Sorry, I thought when you said it was working fine, that everything was okay. I got a bunch of extra O-rings with my TST TPMS, but haven't needed them yet. Only thing I've had to do is replace the batteries, but they've lasted a long time. I do remove them over the winter when it's in storage.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    fj12ryder wrote:
    Why do you want to mess with it if it's working fine? Never forget the old adage: "If it ain't broke, don't fix it".
    Get where you're coming from, but it is "broke". Seals have broken down and leaking, causing alarms after 5 years. I've never replaced them. It's time now and I figured it out; you need a small curved dental pick to get the old ones out. New ones are forced in, they sit in a counterbore; it's not intuitive but I got it going.
    TST gave me extra seals when I bought the unit but they did not look right for the application. Got the old ones out and they're the same as the replacements, so I got it figured out and all is well. TST btw has no heads-up on this online, but overall it's a very good system and I otherwise have no complaints.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    John Wayne wrote:
    When you get the new seals in .Take an old valve stem put a SMALL amount of anti seize on the stem and screw on the sender putting a small amount of anti-seize on the seal. This will prevent the seal from tearing when being screwed on. Repeat every year if you take them off between trips.
    Good tip, thanks.
  • When you get the new seals in .Take an old valve stem put a SMALL amount of anti seize on the stem and screw on the sender putting a small amount of anti-seize on the seal. This will prevent the seal from tearing when being screwed on. Repeat every year if you take them off between trips.
