joelynExplorerAug 22, 2017TT AXLES?????HAVE A 04 TT TANDEM axles that are the torsion type of axles... well the rubber has worn out of them and now the tt dropped so low that the tires are rubbing through the wheel wells... anyone know if...Show More
Ralph_CramdenExplorer IIAug 23, 2017The rubbers can not be replaced. New torsion axles, depending on capacity, run about $350 +/-.Lots of info at Dexter axle to determine what you need based on capacity, start angle, bump clearance, etc.Go Dexter.....stay away from Lippert.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
Related ContentSingle axle TT'sone axle vs. two axles on short TT (20')New TT axlesare there upsides/downfalls to single-axle TT's?Greasing EZ Lube TT axles
