joelynExplorerAug 22, 2017TT AXLES?????HAVE A 04 TT TANDEM axles that are the torsion type of axles... well the rubber has worn out of them and now the tt dropped so low that the tires are rubbing through the wheel wells... anyone know if...Show More
IvylogExplorer IIIAug 23, 2017Replace with axles rated higher than what you have...minimum 500+ although I'd go 1000+ each.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
Related ContentSingle axle TT'sone axle vs. two axles on short TT (20')New TT axlesare there upsides/downfalls to single-axle TT's?Greasing EZ Lube TT axles
