joelyn
Aug 22, 2017Explorer
TT AXLES?????
HAVE A 04 TT TANDEM axles that are the torsion type of axles... well the rubber has worn out of them and now the tt dropped so low that the tires are rubbing through the wheel wells... anyone know if...
rexlion wrote:
Flexiride also makes torsion axles, and they are angle-adjustable.
You could also have a shop convert your trailer to spring axles, and it would probably save you a bundle. Spring axles are cheap and springs are cheap, if they can weld some new mount points onto your frame. I had my cargo trailer converted like this (I damaged the torsion axle, it would have taken 3 weeks or more to get a replacement in, but the shop put on a spring axle in 2 days for 1/3 the cost.)
