myredracer
Jun 27, 2019Explorer II
stallsmi wrote:This is a thought I had too. The contacts in the truck's connector aren't corroded, but definitely dirty and were full of dust. There is a cleaner tool but is expensive and probably cheaper to just replace the connector. All the lights on the back of the TT work great though.
I had pretty much the same problem with my TT and a Ford F250. Turns out the problem was with the 7 pin connector on the truck. After having the brake controller checked, the brake wires completely re-done, I swapped out the connector and everything worked. I got a new connector from etrailer.com.
There's also some connector blocks at the rear bumper near the connector. Not sure if they're related to the 7-pin connector but also another possibility.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
