wa8yxm
Mar 15, 2014Explorer III
First: I second the consider your neighbors comment.
Now.. Two optiosn.. on your 7 pin plug identify two of hte pins Battery (12 volt) and Tail lights.. These two are side by side.
By slightly bending the tabs on a common blade type fuse you can connect these two leads
or you can also do it with a turn signal flasher (use an HD model). if you want to really tick off your neighbors.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
