marc71's avatar
marc71
Tundra Brake Controller Location
Just purchased a new to us 2010 Tundra double cab. Our old TV was a 2002 Tundra.
The 02 had a perfect location for my prodigy P2 controller with a flat location to the lower right of the steering wheel. I drilled a small hole in the back for the wires and it was in the perfect location to read the display and access the brake lever.
Now I'm looking at possible locations in the 2010 and I really don't like any of them. Does anyone have pictures or suggestions on the location in their tundras? Thanks fir your suggestions
  • Hondavalk wrote:
    Mounted under dash left of steering column
    I'm just wondering how you reach the brake lever or even make on the fly adjustments with it being way down there?
  • lots2seeinmyrv wrote:
    We have the 2010 Tundra double cab. We put our Prodigy P2 in the small cubby hole in the center of the console, the cubby next to the phone charge plug.
    Mounted in cubby directly in front of center cup holders. You will need an extension harness. Easy access to get to manual brake lever if needed in an emergency to control the trailer.
    I will try and get a picture posted.
    Im thinking yours has the shifter between the seats? Ours has the shifter on the column, there is no cubby hole next to the phone charger. I've seen pictures of what I believe your application looks like, which is very nice.
  • I have a 2010 Sequoia, and I think the cab layout is the same as the Tundra. I've made a bracket that sits in the recess at the front of the console and holds my brake controller. The attached photo shows it in place. The white material on the right is simply foam wrapped around the piece that sits in the recess to keep it in place without the need for screws. That makes it easy to remove (though I actually leave it in place most of the time). Hope this helps you with ideas for your own solution.
  • We have the 2010 Tundra double cab. We put our Prodigy P2 in the small cubby hole in the center of the console, the cubby next to the phone charge plug.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
