wolfe10
Jan 26, 2014Explorer
If lack of power at or near WOT (Wide Open Throttle), first suspect is fuel filters, as that is when maximum fuel flow is required and restriction will show up first. They are also the least expensive "fix".
Also, what is your air filter minder reading, like the fuel filters, at WOT is when your engine demands max air flow. A clogged filter will manifest itself first at WOT.
Could it be a turbo-- sure, but rule out the common, inexpensive things first.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
