Cameo_Phil
Jul 07, 2016Explorer
I would check the ground connection. Do you have a volt meter for 12 volts? Use a volt meter and run a ground wire to the battery to see if you have voltage at the 7 way connector and at the brake light assembly.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
