fla-gypsy
Jul 08, 2016Explorer
Cecilt wrote:
OP here. Truck is a 2009 F-250. TT is a 2014. I put in a brand new bulb and same result. I swapped the passenger side bulb that worked fine to the driver side and still it would not blink or get brighter when hitting brake. Not the bulb.
Should I remove the housing for the tail light and see if there is a loose connection behind the rear wall of the camper?
On my 2009 F-250 I will occasionally have to wiggle the 7 pin connector to get one side to work. I know you said you cleaned it but this sounds like a connection problem with the trailer connector and 7 pin receptacle.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
