BruceMc
Apr 30, 2019Explorer III
Ditto - Shut 'er down & prop the doors open after a good cleaning.
Now that I joined the choir, I'll add:
Do you have a Dometic? Did you get some blue plastic thingies about 2" by 3" with a U shaped slot & a small square hole? Not knowing what they were, did you discard them when you got your unit??
Our Norcold in the Four Winds has latches built into the handles to prop the door open about an inch.
The Dometic has the blue plastic thingies - snap the U shaped slot over the latch, then while closing the door, push in on the other end if it hits the jamb - the small square hole will latch on the catch that normally holds the door closed. These little widgets are pretty cool, but won't hold the doors in the hold-open position if you head out for a drive for winter warm-ups.... Ask me how I know. Bang! D'oh!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
