boogie_4wheel
Jun 09, 2016Explorer
BB_TX wrote:
Just curious. Side lights would already be on after dark with headlights on. What benefit comes from turning the side lights on steady during the day time? Apparently I am missing something.
Think side/turn flood lights for illumination.
Be patient with me, it has been awhile since I've worked with SS relays. I remember the 'coil' having next to no load.
Would/could you parallel the coil with a resistor to pull down the voltage (bleed the capacitor) to de-energize the relay? If so, you could run a smaller cap and a higher ohm resistor, and adjust the resistor size to control the delay time until the light is shut off. Do you have any components now (a known capacitor size and a few resistors) to establish a baseline for what the SS relay load is?
The 88 ohm coil is confusing me; I looked at it as an 88 ohm load on the cap and my cap size was determined based on that...
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
