wa8yxm
Jun 10, 2016Explorer III
With LED lighting why not just put the cap across the socket and put the diode feeding it.. Radio shack has 5 volt caps at 1 farad as I recall, 3 of those in series (15 volt should do it.. or a decent 20 volt rated electrolytic.. The LEd's only draw about 0.2 amps so given the one second flash rate that should do it, Wire resistance should be enough to protect the fuse but you can add say half an ohm to one ohm if you need to.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
