Jpony56hd
Nov 04, 2014Explorer
It would be a good thing to check the bulbs and sockets for corrosion. This is common and drives service technicians crazy, it will work once and fail the next time. It's usually between the body of the bulb and the socket, interrupting the ground path, causing the circuit to search for another ground path, overheating the circuit, blowing fuses and breakers.
