obiwancanoli's avatar
obiwancanoli
Turning off the Charging Process
After accepting the Limitation that I can't - and shouldn't attempt - charging my new BB Lithium batteries, it occurred to me that a few of the places I might like to go could get to freezing, or below, and gee, I could just turn off, switch off, or otherwise disengage the charging system so that I don't fry my batteries (no pun intended) if they somehow found themselves trying to recharge (I have Solar, and a generator).
Is there a way I can easily disengage the charging process at will, and reinstate when temps rise?
  • FWC wrote:
    pianotuna wrote:
    There are devices that will measure temperature and turn on or off charging.
    Of course, SiO2 do not need such devices.
    OMG!
    If you read the OP and the 3 posts above you, they already have lithium batteries, and the batteries have a low temperature cutoff built in.
    And where did I mention the make of battery? Not all LiFePO4 come with a BMS.
  • PT
    You did not
    But is appears the OP did
    First post says BB Lithium
    I assume that means Battle Born lithium
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 18, 2025
