Dutch_12078
Jul 14, 2017Explorer III
Where did you unhook the cable from the batwing? At the batwing on the roof? Your RV should have an external cable 'F' connector somewhere, often located in the electrical bay. Connecting a coax from that external connector to the park cable connector is the correct way to do it. The cable wall box contains a switch that controls wheter the batwing signal or the park cable signal is fed to your TV, It is also a power injector that sends 12-volts to the batwing's built-in amplifier when the switch is on and the LED is lit.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
