wa8yxm
Jul 15, 2017Explorer III
First NEVER unhook the cable from the batwing less you are replacing the cable or the batwing.. This cable carries, or rather used to carry 12 volts to the pre-amp, which is not the wall switch, but rather inside the batwing.
The switch has, on the back side, 3 Ports (connections)
Ant. Cable, TV-2 (Looking at it from the rear with the 12 volt outlet at the top)
TO use cable you first switch OFF, and then hook to the other end of the cable hooked to the center port.
Suggestion. If you normally use the batwing.. Replace wall switch with a SENSAR PRO (About 100 dollars) Big improvement.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
